Oil sending unit
New for 02 ???
Another Lift Pump ???
Has anyone else out there had their oil pressure sending unit fail? This is what I learned and what I have done to not be caught in the middle of no where with oil running out of my engine.
On the way to May Madness in the mountains of Oregon my oil pressure gauge dropped to zero. Didn't freeze up or start knocking (no louder than usual) so I determined that it was the pressure-sending unit. I can live without that for awhile, anyway till I get to Pahramph and buy a new one.
A few miles North of Tonapah, Nv. oil started leaking out of engine. I lost a gallon before we caught it. The failed pressure switch failed just a little bit more by rupturing the internal diaphragm and letting oil out through the wire plug.
I was in luck, there was a NAPA parts store in Tonapah. They also had the pressure switch for around $28, NAPA part # OP 6670. To change the switch you have to have a very deep 1-1/16" socket. I was in luck again; they had one for about $10. It is part # KD3458. This is the size that fits my ’96, other years may be different.
Now for you adventuresome guys out there like Earthromer, I would suggest that you carry a little insurance in your toolbox. You don't need to buy a new socket or sending unit. This one may have been one in 500,000, but it can ruin your day if it takes your engine out. If you have access to a lathe just hog out the inside of a 1-1/16" deep socket to the depth of 2-3/4". This will allow it to fit over the long sending unit, or you can spend the ten bucks for a new socket at NAPA.
Now you have the sending unit out all you need is a 1/8" NPT pipe plug to plug the hole. This will now keep the oil inside your engine where it belongs till you can get a new unit.
The location is under the injector pump, and not real handy so I made up my spare pipe plug with a two-inch long nipple with a coupling and the plug screwed together. I filed the square end of the plug till a small socket will fit to help install it.
Sorry for the long post, but if it keeps one of you out of trouble it is worth the long read, but you have to do your part by making up your little insurance kit.
Mine Failed Yesterday (5/16/02)
Ron,
Mine failed yesterday, when I was on the way into Reno. The "Check Gauges" warning lamp lit up and the Oil Press Gauge read "zip". I shut the engine down immediately, and coasted to the side of the raod. I suspected that the "Sending Unit" was the problem and thought I'd take it to the Dealer and see if they would cover it under the 100K Engine Warranty. I guess the only thing covered under the 100K warranty, is the engine itself... Nothing that bolts to it. :{
To make a long story, short. The Dealer charged $72 for the diagnosis and wanted a whopping $232 for a new Sending Unit. The total quote came to $458, if I would have also elected to let them re-flash my ECM. I declined, on all counts, and went to the local Cummins Dealer and picked up a new sending unit for $70. Didn't think of NAPA, however, one of the large local parts houses showed no listing for 99' Dodge Diesels, just the Gassers. I don't think I will be visiting this dealer again.
Mine did not leak any oil, just no output signal. The gauge just sat on Zero. When mine failed, I opened the oil filler cap and had my son look at the tops of the lifters to make sure oil was being pumped to the head. In the 99's, the Sending Unit is located on the "Driver's Side", just below the ECM. It requires a 1 1/4" deep socket to remove it (Slightly different than your 96').
Hope our experiences help someone else if they get caught in a similar situation.
Frank
Mine went out at 36700 mi. Real sweet ! Ihad it towed to Dodge even though I was 90% sure that I had oil pressure. Sounded normal, full of oil. I do all the work on it but I'll be darned if I remembered if I had ever seen the sending unit so couldn't even check to see if it was the wire, let alone find it. Cost me $77 towing. Dodge (Breck Dodge Tucson AZ. ) fixed it under warrenty and I turned in the tow bill to Chrysler and 5 weeks later they reimbursed in full.
There also fixing both of the diffs that are leaking at 40000 mi. under warrenty. A true 5 Star dealer !Oo.
