Oil Temp Gauge Sending Unit Location
Horton Fan Clutch installation on '93 Trucks
Probe depth
I just ordered and received an oil (or transmission) gauge kit from TST. They say it can be used for either application, but they don't say where to place the sending unit. I have a 5 speed, so I don't really need a transmission temp gauge. Does anybody have any experience insstalling an oil temp gauge in an first generation Dodge?
Thanks for any and all help,
Steve Marley
Steve the oil pressure sending unit is on the drivers side of engine behind the injection pump. NAPA carries a 1/8 npt tee that has female threads on two ends and male threads on the other end. Unscrew the pressure sending unit,screw the male end of the tee into the engine block and the two sending units into the female ends of the tee.
Gene Hayford
92 350 4x4
Gene,
Thanks for replying to my question. I hadn't thought of the oil pressure sending unit location since I have already installed a T fitting at the location you mentioned to accommodate my Amsoil bypass filter. I'll have to look at my installation again. Maybe I'll add a T to my T.
Again, many thanks for your insight.
Steve Marley
'93 W250 CC, 4X4, 3. 54 gearing, Factory Stock Except For:
16cm2 Turbo Housing, Pacbrake, Amsoil Bumper To Bumper w/bypass,
Boost/Pyro/Oil Temp Gauges, Hella Lights, Turned-Up Pump.
NV4500 5sp, Icom 2 Meter and Uniden CB Radios
Steve there is anther oil port on top of the oil filter housing. It has an 1/8 npt plug. It's next to the oil line going to the top of the turbo. This is where i'm feeding my by-pass filer from. My by-pass filter is bolted on the passenger side engine compartment next to the ac drier. I've run the return line back to the top of the oil filler cap,drilled a hole thur the center of the cap and then used a swivel fitting so the cap still spins on and off.
Gene Hayford
92 350 4x4
Gene,
I had looked at that port and wasn't sure if I could use it or not. Thanks for letting me know. I wish I had written sooner though, as it sounds like your bypass installation is a bit cleaner than mine. I added a "T" behind the fuel injection pump, mounted the filter assembly below the battery on the drivers side and returned at the oil filler cap as you described. Oh well, a bit more oil line strung through the engine compartment, but it works very well.
I'll hook up the sending unit and gauge tomorrow.
Thanks again for the great tip.
Steve Marley
'93 W250 CC, 4X4, 3. 54 Gearing, Factory Stock Except For:
Boost/Pyro/Oil Temp Gauges, Hella Lights.
