oil volume
wiring woes for rookie
diagrams,schematics deatiled pics of common rail cummins
I've changed the oil in my truck several times with the same results. I get 9 quarts out and putting in 9 quarts brings the oil level to the full mark. Is it really possible that 3 quarts of oil remain in the engine?
Are you perfectly level? Did you fill the oil filter before you installed it? The shop manual for mine says 11 quarts, not 12.
Yes, if it has been recently run. I remove the oil filter and drain my oil aprox. 1/2 hour after shut down in the evening. I let the truck drain all night, then in the morning finish the oil change. I get 11 quarts out each time.
