Engine/Transmission (1998.5 - 2002) oil weight questions
2nd Gen Non-Engine/Transmission 3rd Gen parts
Hi, wanting to change out all my fluids with synthetics (Amsoil). Owners manual calls for 90w for the rear and 75w for the NV4500. Amsoil's web site says to use 75w-90/80w-90 for the rear and 75w-90 for the NV4500. Should I try to find another brand synthetic or just go with what Amsoil recommends?
Thanks.
2000 2500 4x4 cummins
I have been happy for the diff, oil running royal purple or redline... I can get redline cheaper than amsoil where I live... I usually run them 25-30k miles. . as far as the nv4500 this transmission if I remember is picky there is only one lube and one only that was a true match and that is the dealer specific for that. I dont know for sure to say if amsoil is a 100% match to the dealer oil. .
I have been using Royal Purple 75W-90 in the transmission and 75W-140 in the rear end. I believe the 75W-140 is recommended for those that tow regularly or tow heavy, 75W-90 is ok for occasional lite towing. Normal change interval is around every 30k for me.
changing the oil now on my 97 been running schaffers full syn 80-90 in trans and diffs have had 0 issues for 2 years and i dont know how many miles.
In Alaska I think I would run the 75w/90. I run 75w/140 in the rear and 75w/90 in the front. I tow a 5th wheel trailer and have the Dana 70(auto).
SNOKING
If you use what Amsoil recommends, you will have no problems! I sell alot of (SVG) Severe Gear 75W-90 for the differentials, well as the (MTG) Manual transmission 75 W-90 GL-4 fluid for the 4500 transmission.
