Diesel Power said:if it means saving money, DC will void as much as they can, yes DC has done it to several people-----------nobody is safe any more![]()
CMast said:After reading all these warrenty issues on here, I was wondering if I could be denighed for using rotella. What oil is recommended on here?
pwr2tow said:The oil has to be API approved not just meet or exceed API requirements or you could run into a hassle with warranty issues.
That being said Rottela is API approved.
CMast said:You must use CI-4 Plus and keep records of the change intervals. If you do extended drains you must do oil analysis.
What does this mean? I right it down in the book, but what is CI-4
amsoilman said:Just to expound on this, the Engine oil DOES NOT have to be "APPROVED" by anyone! It just has to meet or exceed the API specs for that application! When the oil Companies put the specs on the containers, they are saying the contents within meets the specs.
Oils are tested using ASTM or ISO standards, and the API sets the standards for Engine Service Classifications, currently Gasolene (SM) Diesel (CI+4).
The SAE sets the standards for Viscosities.
Wayne
pwr2tow said:That's were marketing comes from. Approved, meet, or exceed oil recommendation does not mean it's certified and tested by API. If the oil jug does not have the API donut with the oil catagories stamped on it the oil is not API certified no matter what the oil manufacturer claims it is. Not having the API donut could (could, not will) lead DC to void the engine warranty.
