Oilguard bypass filter
ever seen one of these?
Snow kit help!
how many oilguard users do we have here? are you happy with your system? i just bought a brand new oilguard system off of ebay for $15. 50!! it is for a 7. 3 powerstroke but that doesn't matter since i will be getting my own lines anyway. which brings me to my next question... where do i get stainless braded oil line from? i figure that would be about the best line material to use. by the way... did you all see that rotella improved their oil a bit? they added to their api rating. :D :D
Oil Guard Install
I finally got time to install mine. But don't really know if I like it or not :) .
It was installed right in the middle of the oil cycle, so plan to wait before changing the oil. Right now about 4k on it. As far as the lines, if looks is your intention then the stainless steel braid is fine. Most that I have seen are installed on frame or battery. I decided to put mine on lower right front below radiator. Also did not like the looks of the hose that came with it, so went to a local hose shop and they made mine per spec, plus all the fittings needed was about 48. 00. They are 3000 psi :eek: . Don't have to worry about them bursting :cool: Also returned thru the fill cap with the AMSOIL fitting.
