OK Frank, I broke down and bought a 94 5-speed
Lift Pump-no warranty-
Notable Quote from my salesman about my new truck
single cab dually. For the best use of my bucks, what do I do in what order to maximize power, logevity, fuel economy and driveability? Where do I spend my first thousand? my second thousand? I'm into the truck for less than eight grand and I use it to carry my 3500 pound Lance and pull either a 7x12 motorcycle trailer (single axle), a two horse trailer, a 38 foot Wells Cargo reverse fifth wheel, or a 34 foot Avion. Mostly in South Florida!
If it's an automatic, fix it.
Then - on to the horsepower! Speed is a question of money, how fast can you afford to go? How much work will you do yourself? Are there any good shops in the area?
I do my own work. There are good shops in the area, but everything in south Florida is inordiantely expensive. IU already stated how much I want to spend. Now I want to know what to spend it on and in what order. :cool:
Good shops?
I havent found one yet!!! Tell me where they are, please. Anyway, you wont be spending a second thousand, unless you need tires or some major stuff. For approx. $1000, you can do a plate, delivery valves, injectors, intake, exhaust, and a larger turbo housing. You will be in the 350hp neighborhood and in need of Peter's clutch!
Brian
Call Piers. I think he's driving the same truck.
Since you have the 5-speed, you don't have to worry with the off -idle stumble, so my first thousand would go like this.
Diamond B 370's
Gov. spring kit (Piers only)
Pump work is free, if you search the archives long enough and do it yourself. All the info is here for 100+ hp gains.
I can't help with clutch selection, but you'll need a STRONG one at this point.
At this stage you'll have tons of power and outrageous EGTs.
It costs a lot of money to cool it down.
Air filters
4" exhausts
twin turbos
head porting
lowering compression
You also have driveability and smoothness mods like:
advanced timing
delivery valves
AFC spring kit or extensive pump tuning
After a year of modifying my truck, my main issues are smoothness and EGT reduction. Both are VERY expensive to cure. > $2000 for each. So, I drive a truck that lopes at idle with the AC on and can peg an EGT gauge by 50 mph.
I've done most of the mods above and I hope this helps.
-Chris
Thanks guys; I guess I should refine my question to ask what improvements I can make that will NOT take me to power levels that will overpower my stock clutch!:eek:
What? JSimpson. You are going to retire the 1 st generation rig? I love those trucks and I thought you did also;) What made you buy another truck, should continue to use the old one. You have a lot of modifications done to it don't you? Oh well, just playin around.
I think with a set of gauges, exhaust, K&N air filter, and a plate you would be making enough power. ~240 :confused: Don't have to spend too much money for a little more power.
See ya
John
Sounds good John! I made the decision for a bunch of reasons:
*5 speed
*power mirrors
*better seats
*better pump
*positraction
*availability of parts and accessories
Now the hard part is figuring out how to make the second gen look and run as good as my first gen!:cool:
Call Piers!
I would suggest 215 injectors, a larger turbo housing and a #5 plate from TST. (My set up, drives completely different, good mpgs too)
Then buy a clutch, don't even bother with trying to make the stock live!
jsimpson:
All congrats to you on your "new" truck purchase. It's good to see your intelligent quest for the big four needs: POWER, LONGEVITY, FUEL ECONOMY, and DRIVEABILITY.
There has been a previous post by Ted J about the "proper order of upgrades"... good reading and accurate advice.
I'd suggest giving Ted a call and checking out the links for Ted's and the other top notch suppliers of engine/truck upgrades and expert advice.
Keep in mind that as a daily driver that truck can and should produce ALL of the BIG FOUR attributes as mentioned.
Best of luck
Frank S.
