cArNiVaLwOrKeR said:If you have $ 1st of all don't tell your oLd LaDy, then git, Injectors, Mach3's 4, or 5's. Box,AFE intake, GAUGES! ! ! Bigger Turbo, pusher pump and B0B4X4 could think about several more items that could Bankrupt you before you even know it, He is the best and he works on my truck only and noody else lays a finger on it.
BigDan said:I dont think they make mach 4 or 5 injectors for 2006 CTD.
Since you asked what you should do first I'd get a Smarty and if you want to run it on a higher settings you will have to change and spend alot more $$$ on other things like gauges, turbo, transmission upograde
Diesel Power said:guages first, then transmission. Oo.
CHolman said:Ditto, you can add all the power you want, but without a built transmission, how do I say this? "your screwed"...![]()
