Why are the intake and exhaust manifolds different?
WMonroe said:Why is the oil pan sump in the front instead of the rear?
Will
SRadke said:The bellhousing is typical, the extra hole is where the air compressor would mount. They also mount the engine from bellhousing and up front rather than from the sides in the middle like Dodge. Only thing that seems odd really is the front sump pan.
The extra hole on the left side is where the barring device goes. The bellhousing style is typical Freightliner. Front sump pan was used on many applications.
rbattelle said:I notice a large chip in the tan paint on the #5 valve cover. Paint beneath looks like the same color as the inside of the bellhousing.
It looks like someone sprayed the entire engine with a coat of tan paint without masking anything off except the bellhousing and what looks like the engine data plate. Even the stand it's on was painted, you can see the overspray on the pallet.
That is not a chip in the paint. It is a small Cummins badge on the #5 valve cover. Thats the way we paint our rebuilt engines.
