okanother smarty ?
Mag-Hytek pan install with Redline C+ATF
SBC DD breakin procedure
:-laf Well i just got my 3250 SBC DD installed yesterday. My question is can you tow heavy using sw#9 on the smarty or should i stay with lower settings onthe smarty. i got the newest revo loaded right now. thatks for your opionns or coments. :)
I would think you would be alright as long as you kept the EGT's in check since you have upgraded your clutch to handle the power your next problem is gonna be the EGTs
Well that depends. I don't see anything in your signature that would put enough air (or water) into the mix to keep EGTs in check on #9. Outside of the engine, the clutch would probably take it not sure about the rest of the driveline.
I usually tow on 3 and have been ok with EGTs, but not sure it would handle anything higher before things get out of control. Of course my clutch might not be happy towing above 3 either...
