'Ol blue getting a GV overdrive???
double clunk???
Truck purchase information needed
Guys,
I need some feedback from you on the Gv overdirves. I've checked the forums and not alot of info. Anyone with a first gen with a GV overdrive unit??? I just changed jobs and will be driving interstate to work and tohught I'd like to cruise to work at low rpm's and try to get better mileage. I'll be driving 45 minutes each way, so I tohught the unit would pay for itself in a while and it should be a cool tow to have while towing.
Later
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Check us out at:
http://donstractorrepair. homestead.com
I instaled a GV in a 6 cylinder diesal and it went out two times. If you can call GV and speek to the owner. He sead that a high HP 6 diesel motor will tear up a GV. It is not ment to take the high thump that a 6 with high HP puts out. Said they will stand a 1000 HP v8 but a 6 that puts out power will give problems. Phone for GV in souther Cal. is
1-800-999-9555. Hope this helps. I have a remote mount GV in my garage but wont put it in my bommed truck but may mount it in my 35 Ford Pu. Just my 2 "
93=4/4- Trailer tower. Flat bed. hx-40w turbow,hot end opend to 3. 75. 4" from turbo back. Pump set and timing maxed out.
34 lb wot, no trailer. 308 gears. 5 speed. need more powwer. powwwer. powwwer.
I have a friend who has a GV OD in his 96 5 speed with a 4. 10. He pulls max gvw. He has a 44 pace bigfoot. All loaded he is 25,500. He has had no problems and his has the cam plate adjustments. He can certainly run with the Strokes.
Mark Faught, 92 ext cab service truck and a 84 crew cab one ton dually with a 91 cummins and NV 4500.
WELL, *I* have the US Gear OD and 3. 07 differential - mine IS an OD, not UD, and with your 3. 54's, I would SURE want OD instead of UD! The OD will give LOTS less engine rpm at freeway speeds, but still deliver nice splits between gears... #ad
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... Tweaked pump, upgraded radiator... MORE than a match for every new PS Ford encountered so far...
"Dura" WHAT? NOW I know where all those recycled beer cans go...
