Thought I'd send an update on 'Ol Blue, my 89 D250 Cummins. It WAS pretty hot. The other day I thought it blew the head gasket(see post on blown head gasket). I pulled the head and took it to a reputable shop who told me it was cracked. I then called Cummins and they acknowledged that they had cracking problems with the pre 91 heads. So for 651. 00 I bought a recon head. Atleast I think it is a Recon. Can anyone tell me how to tell new from Recon. I know it should have some #'s stamped on it. I also had to buy injectors(65. 00 each) cause mine had 9mm holes in the head and 9mm injectors. The newer(91 1/2-98) have 7mm holes in the head and 7mm injectors. I also bought a complete head gasket set($120), are they marked recon on them anywhere?? I am really pleased with the parts. The head and the injectors look like new. If they are recon Cummins does a really fine job on them. They sold me a standard head gasket. I thought a resurfaced head needed special injector washers and a thicker head gasket. The service guy said bolt it on and roll the engine over; if it does not lock up then you are fine. I can't belive he told me that. I need more info before I put the head on to ensure I have the right parts. So now 1301. 72 poorer, I will start cleaning the top of the block tomorrow and paint the head.
thanks for any help you can give.
later
Don
1989 D 250 Ice blue met. 5 spd 3. 54, 140,000, Banks stage III powerpack straight exhaust, pump adjustments, still looking for more power ON HOLD DUE TO BLOWN HEAD GASKET!!
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let the BOBMing begin!!! 275hp injectors installed, boost and pyro gages, awaiting results of those who have purchased the VA box.
later
Don
