Competition Ol Red does 807hp Fuel Only - Monster VP
Competition Aftermarket Cylinder Heads
Competition 886 HP and 1770 FtLb 12v
Fuel only got me to 807hp and 1546ft/lbs. My MaxSpool cam from Comp461, Twins from BPonci, Dynomite Diesel Injectors, and the Monster VP from Northeast Performance Diesel really worked well together. Thanks guys for the all the help.
Were you running added electronic box or programmer? What settings if yes? What type of dyno?
SWEEEEEEEEEEEEET Great #'s. :eek:
TST - wish I had a Redline to try. It was a Dynocom dyno - much like the DynoJet but a little heavier roller and much easier braking system.
Somebody's always gonna have something to say negative - point is it made the power. Here's the video guys.
<embed src="http://video.competitiondiesel.com/vidiac. swf" FlashVars="video=db0626c2-729d-48d4-a4ed-99e70106a5f4" quality="high" bgcolor="#ffffff" width="428" height="352" name="ePlayer" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
AFarmer,
Ol Red is awesome. Can you daily drive that rig? Is it real smokey or no? What Stage pump is that?
That's a pretty clean run on the dyno til you stomped on it. Thank you for the video.
Great numbers!
I understand you don't use a timing box with that, does this pump already have advanced timing in it?
P. S. You have to try the RedLine, Pulls had like the tst but it just keeps going.
Pump has a pretty good bit of timing already built in so any more really isn't needed. I'm working on getting a Redline to try with this setup and see what that does.
