oliver crawler 0c3 question
Latest Darwin Award Winner
Case IH 585
:) Any Oliver oc3 or hg people out there? I need the thickness of the steering brake band lining on my oc3. Thanks guys. Tim
Been a long time since I've seen an OC3 or an HG mentioned.
Wow! What are you using it for?
We bought a Forest Service OC3 and added a blade to it back in 1965.
Wish I still had it.
OC3 and OC4
:) I found a fellow in Penna. who has all the parts that I need for the oc3 and the oc4 that I have. The 3 has a blade on it and you would be surprised how much it can push. I built a set of forks for it to move logs around and it worked great. The 4 has a loader on it and is a 3 cyl diesel and weighs quite a bit more than the 3. I haven't used the 4 yet, but it runs good and has a broken hyd. hose at present. These are remarkable little crawlers with a narrow track with (60"). Pretty old and I don't overdue these machines! An older cat skinner told me not to add any weight to the rear of the cat, as so when the tracks spin, back up and repush. This way, you don't bust up everything. Tim:) :) :) :) :) :)
Fellow in Pennsylvania
Would that be Zimmerman Oliver-Cletrac, 1450 Diamond Station Road, Ephrata, PA 17522 717-738-2573
Mon-Fri 7am-5pm
Tim1,
There used to be an Oliver parts place in Lewiston, Idaho... don't know if it's still open. I wish I could remember the name... I believe it was in the Lewiston Orchards.
We had an Oliver HG Cletrac with a small loader on it. The planetary steering system on it was the best for traction while scooping S*&t!!:D
Loren
Zimmerman oliver cleatrack
:) Yes, the fellows name is Landis Zimmerman. Very good guy to do business with and he really knows these old tractors. Will have my parts soon, then will push some dirt for the heck of it. Thanks for the replies fellows. Tim:)
