John,
I moved the coolent overflow bottle about six inches, and placed it next to the radiator. Probably not the best place to have it, but it fit in there snugly, and sems to work just fine.
I have been asked by a couple other members for drawings of the mounting plates. I will try to take some more detailed pictures and draw up the mounting plate and post it somewhere.
Yes, that is a 1/4 inch turn buckle (rated at 90 lbs of working load)
used to adjust the belt tension. I did not want to have to fight with holding tension on the elt while I tightened the mounting bolts, so I devised this pivot and turnbuckle setup. It seems to work pretty well so far. Currently, it just has a stock hole in the alternator bracked, but I think I will weld on a small piece of quarter inch steel to the backside and tap all the way through for added strength.
The system has been on the truck for about a month now, and in which time I have put about 3000 miles on the truck, and ran the compressor a tota of about an hour. It ir really nice to have impact gun capability at the flip of a switch.
Mark
