I like my Premier Power Welder
I am very satisfied with my Premier Power Welder. I got it with a 200 AMP alternator. It is a great welder. It produces a high frequency arc that penetrates better than a straight arc welder. It is also a rapid battery charger and can charge a truck battery about 80% of capacity in two to three minutes. It also gives me 120 DC which can be used like AC for most tools that don't have variable speed controls, so I can use my disc grinder to prepare metal for welding and cleanup welds after. With additional equipment, it can become a mig welder and a tig welder. Its main problem is the polarity requirement means that you must take whatever you are welding off the truck. You can get around this by just using battery power but to weld you own frame for instance is a bit problematical. Overall I have found it very useful and a great tool. I have surprized quite a few people in Baja by being able to weld up their vehicle or recharge their battery on the spot.
