? on HTT Stage 3 upgrade/turbine wheel and shaft removal
DD Jammer Turbo
Mail Order Lift Pump
Hey guys!!!
Got my stage 3 kit in from HTT yesterday and am having some trouble getting
the center cection machined.
I took the compressor housing and wheel off and am wondering if you guys are
taking the turbine wheel and shaft out of the center section before trying
to check it up in a lathe.
I took my center section to a buds house last night and his chucks for his
lathe wasnt big enough to go over the turbine wheel and chuck up on the
center section. If I had the shaft and turbine wheel out of the center
section machining it wouldnt be a problem.
How do the shafts come out??? I checked on the Hoset site and if I am
reading the manual right they just slide out of the center section after
removing the compressor wheel. Are there any seals that will need to be
replaced if I take the shaft out??
Now granted this is not the first turbo I have been into, but it is quite a
bit different than the ol garrett turbos that we used on the turbo buicks.
Thanks in advance!!!
Btw sorry for the multiple postings, but I really need this info ASAP so I can my truck back on the road.
