Engine/Transmission (1998.5 - 2002) ? on replacing rear axle for disk brakes
Engine/Transmission (1998.5 - 2002) engine code p-ecu ???
Engine/Transmission (1994 - 1998) Hints to setting the valves..
Ok guys... I am about tired of the drum brakes that just plane out DON'T WORK!!
I remember seeing a kit on here about 6 months in which you can replace your rear axle with one that has disk brakes. Does anybody have any idea whom the vendor was?
Also, is there a way to just replace the brakes, or will I have to replace the entire axle? How about the ABS stuff? My truck has RW-ABS. Will my abs just not work, or will it connect into the new breaks?
I've never done an overhaul like this... but I am ready to start researching everything so that I can do it...
Thanks Everyone,
Kev
Kev... Suggest you include Sam Peterson [I believe that is his last name] in your discussions. . he is the brake guru in the northwest. . sorry I don't have a link to him
Trust me... . Sam's at the top of my list.
Once I can find out what all I need as far as replacing the brakes... I am going to give Sam a call and see if I can use a little bit of his expertise to insure I get the right equipment.
Kev
