A couple of weeks ago my truck started missing when on the throttle. Got a PO253 code. Checked electrical connections and cleaned grounds because I've had ground problems before. Truck still missed and had a PO253 again. Figured it must be the injection pump. Read alot of posts leaning toward the VP44 being bad. So I installed a reman VP44, truck still misses and has PO253 code again. :{ I've had my edge comp(no pump wire hooked up) stacked with my tst powermax competition for two years and worked great. The tst makes my truck miss. If I disconnect the tst or turn it off and hook the edge to the pump wire the truck runs fine, no engine light or miss. I put the tst in a buddies 98 2500 and it works fine, plug it into my truck, get the miss and engine light. I have good fuel pressure and tried a new map sensor and swapped injectors. Still no change
Sorry for the long post, any ideas would be greatly appreciated.
