9007 pinout
I agree with Ron - if the high beam seems to work then this may be the problem. If you have the standard headlamps (non-sport), I think it's a single 9007 in each lamp. Looking at the back of the connector with the flat part to the top, it should be LOW (left), GROUND (center), HIGH (right). A simple test light will confirm how yours is pinned (check both sides to be sure). Use a small jeweler's screwdriver to release the wrong wire from the connector by pushing it into the small slot under the terminal on the front of the connector and gently pulling the wire out of the back. Push the terminal (and seal) back into the right position and test the lights. Hope this helps.
