One last time, FRANTZ FILTER
Amsoil by-pass adapter
2000 Ram 24Valve and BOOST and a 5 spd
Are you running synthetic fluids now? Do you have any intention on running extended drain intervals?
If you do not plan on running an extended drain interval, say over 5k, with either syn or dino oil I personally think bypass filters are a wate of money.
Look at some of the low mileage oil analysis? There is very, very little wear with short oil change intervals.
If you are planning on extending the drain interval then the benefits of a bypass filter are more prevlant, IMHO.
With that said, I agree the Oilguard seems to be a better unit that the Frantz.
If you do a lot of extended driving, the Spinner is a pretty slick bypass filter. The problem is it only works best when oil is up to operating temp for extended periods of time. If you do alot of short in town driving it is probably not the best alternative.
I have a Frantz in the basement. Problem is oil leaks, that can be tolerated. What I could not stand is to take the thing apart and see the channels that the oil and pressure had found to get around the filter element (toilet paper) I will sell you that filter assembly for a lot less than $165
