One week on my PDR HX-50/55 Hybrid.
Flames out the stacks ?
need allot of input please--air filters???
Not to pop a buble or anything....
I'm not quite sure what housings are on the B-1 but, I run my B-1 and comp box at 4-3 every day and not go over 1250 on the pyro... ... The spools up is great and I'm pushing DD SuperMentals:D
I can run 85 MPH and sit on around 25psi horsing around, if I run at 60 mph I sit at 3-5 psi and with a touch of the peddle I'll instantly hit 46psi with the same DDUFM level. If on 5x5... forget about it... ... . :D
I am seeing 57 psi with the box on 5x5 though Piers would like for users to keep the boost at 55. Driving down the freeway I am cruising at around 5 to 7 psi. That is really hard to give exact when the guage starts at 5 psi. Tires start breaking loose at around 1700 when the box is on kill. Might be sooner if I had the 89% TC but I don't want to give up the fluid coupling. Like I've said, been running on 1x3 and the turbo spools up great. Happy camper in Washington. :D
Chipstien
Your 91 is the way to go at that power level, at our power levels we begin to drive through the 89, if you add more fuel PM me and I'll send you the parts list for an external wastegate like mine if you want to go that route, I talked to Al fri about that turbo, I didn't realize the drive pressure was as good as it is.
Jim
Mark has a kit, so does HVAC, and Dave Mitchell does too or you can build it yourself, just depends on what you want and your avaliable resources... ... shop, tools, skills, ect.
Jim
Jim
Mitchell, HVAC, Mark, and J. R. Adkins, and I'm sure Piers could do ya up a kit also if you asked nicely. :D
John(SB), I want a set from you!:D
Andrew
I'm sorry I did not explain myself more clearly.
I thought Mark was offering a kit with the piping only and not a complete twin turbo kit. I thought that was the intent of the original question.
I assumed (that was my problem :rolleyes: ) that Bill was aware complete turbo kits are available. Sorry that I did not include some of the great innovators in my original post.
Well I've had my hx40 and 275 injectors on the truck for 3 months. Just ordered DDIII's from Piers. I bet within 1 month I'll need the HX50/55 dam I feel real bad about my sickly truck. :rolleyes:
