online 3200 spring kit info
Alternative fuels... anyone?
Craiglist find
Is there a website i can order the 3200gov spring kit for my 93 online? what exactly will i gain out of this kit?
________________
93 w250 LE 4x4, NV4500, POD's, PDR HX35/16, open air, straight piped to stacks, pump mods, south bend, borgsen steering shaft & gauges.
It's not a kit, its simply a spring. You won't be able to click and purchase online. You'll have to pick up a phone or go face to face with a shop. Any Bosch/cummins shop can get you the spring if you give them the part number. By all means do not go in there without a part number.
Gain- you'll increase your fueling point of the pump to 3200rpm. Stock is much lower than that. Yes you can turn more than 3200rpm's without this spring, but you're not max fueling at that point. Instead of the engine falling on its face at say 2500, it will continue pulling, fueling to 3000-3200.
Ol'TrailDog,
I think for a 97 you need a kit, check with the 2nd gen guys, the 1st gens 89'-93' only need a spring change.
Good luck,
Caleb
