I am wondering about changing my gear ratio or if I should add a Gearvendor over/under drive. I currently have 3. 73. I know dodge offers a 3. 55. I got an estimate of $3300. 00. That is about the same price for a gear vendor. Which one is better?
Badger,
I see you are new, with only two posts so far. You started this question in the wrong place. You wanted to start a new "thread". This thread deals with on-line repair manuals, and your question doesn't involve that.
Here's how to do what you want:
1. Go to the appropriate forum, for example the "3rd Generation Ram Forum (NO engine/transmission discussions)"
2. At the top of the thread listing, at the left, is a small "button" labeled, "NEW THREAD". Click on that.
3. This will send you to a new page where you can enter your thread subject and the first post.
By the way, my opinion is that you should go with the overdrive transmission instead of changing differential ratios, especially if you have a 4WD with two differentials.
I have the U. S. Gear overdrive and I like it a lot. If you get a GearVendors you cannot use it in 4WD. Also, the GearVendors advertising is misleading. They do not make an underdrive, only an overdrive. They justify calling it an underdrive because 2nd gear overdrive is the same as 3rd gear underdrive.
Welcome aboard.
Loren
