Open Differential Woes...
how much is my dads truck really worth
OIL
The new found power in my 94 Ram has brought forth a problem, a bald right rear tire. Having an open rear wasn't a problem when the truck was stock, now... well, i'm sure you guys know! I'm looking for an inexpensive solution. Is there a spool available for the Dana 70? I mostly do highway driving and don't encounter too many tight turns, so I don't think a spooled rear will be a problem.
Insight??
94 Dodge Ram Cummins Turbo Diesel (owned since new) warmed over by Auto Wurks... 15. 18 @ 86mph on 285/75/16s
10 second 87 Buick Grand National
11 second 87 Buick T-Type
Exhaust Driven!!
[This message has been edited by turbonatr (edited 03-13-2001). ]
turbonatr,
On the cars I have driven and owned with open diffs I never had problems with only one tire getting bald faster. When I did a burn outs both tires would leave rubber behind. But maybe I was lucky.
I think as long as you have the same amount of traction on both rear tires they both spin. Now if you have steering wheel turned only one tire should leave rubber.
Than again I could be dreaming.
Bill Thomas
Missouri Mule - 96 Wht 4X4 ST CC,5 spd, 3. 54, 8 ft bed, 1 ft high cheater boards.
99 Freightliner bl/wht FL60 ISB-5. 9 24v,215 hp,520 tq,6 spd, 3. 59 nsr,16 ft box, 19. 5 tires,Wt/gvw 11,000/23000
turbonatr;
Look here. http://www.powertrax.com/ They do not have the no-slip system out for the Dana 70's yet, but fron the conversation I had with them it is on it's way. You just may have to wait a little while. Give them a call and you can get the latest date.
96 2500 4x4 Driftwood auto Warn 4x boards pyro,boost,trans temp on a piller, mag hytec trans pan, Reese 15k 5th wheel hitch Pulling 200 Alfa Ideal 31RL
Keep your eyes on the classifieds. Sometimes you will see a limited slip on there. Not as good as a locker but less expensive. Besides, we ARE talking about your TOW vehicle right? #ad
Gee, I bet that with your drag racing connections, you could probably come up with an old pair of slicks, borrow some wheels...
"You just taken your first step into a larger world. "
'94 3500 4x4, 209,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: X-Mount Mirrors, 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
Occasionally both rear tires will spin, but the majority of the time, it's the right rear. Quite frankly, it's getting old! Any more than 1/2 throttle from a dead stop and up in smoke the right rear goes. Bewteen the right rear tire squeeling, and the 3" straight pipe, the truck is quite the attention getter... I can grab a cop's attention from 3 blocks away. #ad
Anyway, thanks for the insight and link!!
Exhaust Driven!!
