The window switches on my 2003 have a intermittent problem. I am sure its due to snow falling in the cab this winter when the door is open. Snow melts and runs into the switch contacts and causes corrosion.
I proved the switch assembly to be the problem. Using jumpers to jump contacts in the connector, I have normal control of the windows.
I figured, open the switch assembly, clean the contacts and probably all will be well. With the switch assembly removed, I removed the small screws around the perimeter of the assembly. I unsnapped the plastic locks holding the two halfs together. It still will not separate, something dead center in the switch assembly appears to be holding the two halfs from separating.
I dont want to break the switch, how do you get the switch to open up.
Thanks
WM300
Thanks
WM300
