It was suggested to me that I try a fuel additive called TriPak, for improved fuel economy. The major component in the material according to the MSDS is isopropal alcohol, that alone said "stay away" but the amount was 10-30%, that even makes me more nervous. The amount used is 1oz. per 5 galllons - -when I talked to the rep, he told me the alcohol grabs the water and takes it to the bottom (should have been there any way). The way I see it, the bottom pickup in the fuel tank, will grab this alcohol/water mix and carry it through the water separator into the injection system - - and there the problem begins to cause problems. Am I correct in this or am I all wet? (No pun intended.
Guys - - I am interested in YOUR opinion
