I headed out this morning and in about 2 miles the CEL came on and the truck started missing and wouldn't take any throttle. It also sounded like an old 12 valve motor with all the knocking and such. Coasted into a parking lot and read the code which was a P0192, (Fuel Rail Pressure Sensor Low).
After trying to restart several times it did finally restart and I made it back home. I noticed my lift pump pressure being erratic and somewhat lower at about 6 psi which is about 2 pounds lower than usual. I immediately thought it was a faulty lift pump as mine's still the stock one mounted on the filter housing. I decided the lift pump was the problem and drove up to Geno's and picked up a FASS with the filters.
However, after researching many posts most people seem to be replacing the rail pressure sensor. Well with the erratic lift pump pressure what's your opinion?????? The rail pressure sensor is another $229 at Geno's. It seems terribly expensive for such a small piece. Do you think I need it???
RAIL PRESSURE SENDER ('03-'07) 5. 9L-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Thanks for your thoughts,
Bill
-----(I'm sure I need the FASS with my mods so I'll install it anyway)
Bill
