Details here: TDR Privileges
Anyone have or know of a good bracket or mounting hardware for the Optima batteries when used in stock battery location? I'm running Optime red tops. They are slightly undersized for the stock battery box; so I have them shimmed with some rubber pieces but would like a nicer solution.
sometimes Autozone has the little plastic pieces that you need to retrofit the smaller batteries into the Ram trucks, I had the same problem today when swapping batteries
BigMak, I have the Optima red tops and was able to use the factory bracket to hold the bottom of the battery by angling it a bit and tightening. Been that way for 33k miles and no problems so far. fwiw
