OPTIMUM FUEL PSI?
Don't get better than this
Would you do it?
DC manual says 25psi immediately after pump is min std. Does not indictate a range.
TST is saying 28-36psi @2000rpm on outlet side of filter/sep, which I'm not getting.
I have the 25psi min.
Everything has been checked or replaced(overflow/lines/both prefilter gaskets etc) everything but the pump.
Is this pump not operating to optimum spec?
And is there any performance to be had increasing psi from the 25psi min to the 28-36 @2000?
Thanks
Mike
94 2500HD 5sp 4. 10LSD 4X4 RWAL w/GearVendor OD, K&N Oval w/ Pre-Filter, Straight Exhaust, Geno's Fumotovalve, AW-Direct Idle Controller, DiPricol Boost, Mag-Hytec Rear, 124K miles. Halon Protected, NRA Member. V1.
[This message has been edited by mikepvg (edited 04-04-2001). ]
