Engine/Transmission (1998.5 - 2002) Options for transmission temp sender locations
2nd Gen Non-Engine/Transmission axle fluids
Engine/Transmission (1998.5 - 2002) 2002 Auto lockup Question
I was going to order a mag Hytec because it was already tapped for the temp prob. & other reasons. . But then I was thinking with the miles I put on the Tanny service comes around often and do I want the pan hanging by the prob wire? can it be easily reconnected? any options you guys have used.
47RE auto by the way. Thanks JJ
Jim the wire is just clipped on like a speaker wire, sources will tell you to change the supply line out of the transmission for the one with the fitting installed for a temp probe as this is the hottest the fuild will ever get, and that is a true statement. I have a mag-tech and just monitor the pan temp.
Jim
