Ordered 3 gauge package-need wiring ideas.
UTAH Dyno Days
Fast Idle
Pyro-Boost-Trans Temp, on the way with A-piller. I don't have "painless wiring", so any ideas on wiring these up correct would be appriceated, ie... wire color codes to splice into.
Gauges shouldn't cause a heavy load on stock wiring? Is there a wiring devise that will alow me use the stock fuse box (fuse) to power all 3 gauges, then tap into the light switch for lighting? Hopefully I can get to the light switch wires.
Max
There are a bunch of posts on this if you do a search. The gauges wont cause any heavy load, so no need to worry. I got my lighting power source fromt the Tan wire behind the headlight switch. For my switched positive, i used the power window fuse. This way the gauges turn off when the truck is shut off. For my ground, i just used a self tapping screw into the metal dash support. If you have any specific questions, just let me know and ill walk you through it, good luck
Every thing you need except the sensor wires can be foung in the fuse box by the drivers door. Wrangler Products has fuse clips tha allow you to add lite load circuits at this location.
Denny
