Guys I need advice. Four Gauges are on the way from Geno’s. All black faced Di-Pricol. My plan is to locate on the A-pillar starting top to bottom EGT, Boost and Fuel Pressure.
In the small shelf opening just right of the radio I may mount the transmission temp…. or maybe below the ashtray area in a rubber donut mount, I haven’t decided yet but ordered both mounts.
I ordered the tapped banjo bolt and washers for the fuel pressure and was planning on locating it BETWEEN the fuel filter housing output side somewhere and the ejection pump, anyplace better than another opinions please.
From Geno’s in regard to the DiPricol Fuel pressure gauge it states.
“Our kit includes the gauge, light kit, under hood isolator (1/8 NPT female connection) and tubing to attach to the back of the gauge.
Customer will need to supply parts required to connect the isolator (1/8 NPT female connection”
So I need to connect the banjo bolt to the isolator with that nice braded hose (where do I get that anyway) 1/8 NPT (male) to banjo bolt and 1/8 NPT (male) to the isolator (what does NPT stand for anyway).
Advice please.
Also Routing of wires where to tap dimmer control. And any other advice regarding what “I haven’t thought of” would be greatly appreciated.
Thanks JJ
Advice please.
Thanks JJ
