2nd Gen Non-Engine/Transmission Ordered guages.....
Engine/Transmission (1998.5 - 2002) Time to change the big ol'drive belt?
Engine/Transmission (1998.5 - 2002) Dakota Digital F.P. Gauge
but I am wondering if there is anything else that I have overlooked. I have an '02 QC 4WD 2500 with the five speed. I ordered the westach H/O combo guage and the FP guage from geno's with the dual a pillar pod.
I have searched for info in this but couldn't come up with anything. I want to install these next weekend so any heads up you could give me would be appreciated. This is my first diesel, and my only diesel (unless I buy another cummins:)) Sorry for such a stupid question but I am going to do this right.
Also, if you wouldn't mind. What do I have to do to the fuel system if anything to be set for an EZ Comp. I am getting a 4" exhaust the same time I get the EZ.
Thanks for the help.
Mark
Mark
you will need a sender too and do youself a favor and get a whole set of Rays banjo bolts , get 1 with a 1/8"npt tap for the sender to mount from . sounds as if you are on track to doing it up right .
On the search select the products accesory forumn while searching and it will be there... ... ... ... ... . Kevin
Thanks for the reply, I forgot to mention that I have all the senders for my guages coming also. I did order banjos. I got two tapped and three standards with the gaskets (whatever they are for) I am still unsure of where these things go, or what they do, or why I even need them (other than the fact I need a tapped one for the FP sender to go into) Do I have to tap the intake somewhere to install the boost sender? Or is there a plug anywhere that I can use.
Thanks for all the help
Mark
Mark
I have 2 tapped banjos , I read both pre &post filter , I installed a switch so I can use only 1 gage though, if you dont want that than just put a 1/8 "npt plug with T-tape in it & it will serve as a regular banjo.
I drilled and tapped my aluminum air horn for the boost reading but others have found existing fittings that they fitted to.
