Swayze,
The off center front axle is a classic problem when we lift the front of the truck. Mine is barely measureable. Maybe 3/8"-1/4" shift to the left. I decided to just live with it.
If you have access to a machine shop, you could probably cut the bar and lengthen it. One member has done this.
This is from an older thread with good info:
Our selection of aftermarket adjustable track bars is very limited.
You may try to get a drop bracket from Trailmaster, Skyjacker, or Rancho ect. You will have to speak to their techs. Not sure if they are sold seperately.
It appears Linstad`s bar is not adjustable lengthwise like you need. Its adjusable as the ball joint wears, to take up the play. I don`t know that much about it. I could be wrong.
More info on Linstad:
http://www.westdakota.com/lindstad/
Probably the best trackbar for our trucks is the DT HEIM Joint track bar. (Pictured below) Its is fully adjustable lengthwise to push your axle back to center.
A note: I had the DT Heim joint T-bar 1/2 way installed in my truck. It was on a Sat. DT was closed. I had tech questions. One of the 4" bolts that holds the bracket to the trucks frame is supposed to go thru a hole at the bottom of the frame and the top. Well the holes are 1/2" out of line. The bolt will only go in at a 30 degree angle. No way I could get a drill in there to straighten the holes. Second problem was the bolt was too long. It butted up against the steering shaft. Reverse it and it hung to low. probably would interfere with the piman arm. The only problems I had were with the bracket that replaces the factory tapered ball joint mount on the frame.
I got fed up and put everything back in the box and shipped it back. Talked to DT HEIM joint that next Monday. The long bolt is supposed to be tightened at a 30 degree angle (way cocked). It just didn`t look right. DT HEIM joint said they were upgrading the bar to include a "turnbuckle" type lengthway adjustment. BY NO MEANS LET MY EXPERIENCE WITH DT HEIM JOINT PERSWADE YOU IN NOT PURCHASING THE BAR. I just had bad luck. It was one of those days! LOTS of guys love it.
Great info on DT HEIM JOINT T-BAR HERE:
http://www.ecpe.vt.edu/~dfritz/technical/STEERING/trackbar/dt_install.html
"BigBadDodge" a member here has the DT Heim joint trac bar installed on his truck. You can see good pictures of the bar here:
http://communities. msn.com/ScottsRam&naventryid=110
[This message has been edited by HEMI®Dart (edited 12-16-2000). ]
