Outlook Monitor + analog gauges ?
Anybody Jacobs sqeak?
anyone coated the factory bumpers?
Is it possible to use the Outlook Monitor pyro probe for both the Outlook and an analog pyro gauge? Want to install a 3 gauge pillar with the Outlook on top and analog boost and pyro below. Should be able to read (eyes aren't what they used to be) the digital readouts better in the daylight. I want to use the analogs as a backup. Did a search and found some "you should be able to... " answers but I'm really looking for someone who has actually done this. I'd really rather not drill and tap for another probe.
Well, it works. The Isspro pyro reads about 50 degrees higher than the Outlook and the boost gauge reads about 4 psi higher than the digital readout. The Outlook shows 3 psi at idle so the gauge is probably right on.
