Outside Ambient Temp Sensor
overboost code help
Dealership in Ada ,Ok, Comments?
It seems as of late my outside temp gauge has been reading a little higher than what's going on outside, even when the truck has sat all night and is cool to the touch (engine).
I located the sensor (underside of hood) next to the hood clasp/latch and it appears to be well sealed.
Anyone have problems w/ these gizmos? Hopefully they last AT LEAST AS LONG AS A FUEL SENDER?
Thx
Max
It seems that you have to go down the road a few miles before they read accurately. Ive noticed as well that,after sitting all night,its not reading properly. Once the truck is moving air is circulating around the sensor and it will be within a degree if not exactly reading as per the weather report on the radio station.
2001 HO 6spd,Quad cab,LWB,4x4,Flame Red,all options except for leather,Westin Brushguard/Push bar,Painless wiring,Radio Shack CB( so what it works},my own designed CB mount,Smittybuilt nerf bars,NW Custom rocker covers,Custom built stainless rocker light bars(more to come)
I just had mine replaced under warranty. At times it would be stuck on one temp. It was stuck on 46 one day when it was in the 20's. #ad
2001 2500; SLT; 4x4; QC; LWB; Auto; 3. 54 LS; 265s; Camper; Tow; Sliding Rear Window; Travel Convenience Group; Cab Clearance Lamps; Forest Green
The sensor,at least on the 12 valvers,takes a reading once per minute. When you shut down the temp is stored and diplayed for one minute after you start up again. Thats what you're seeing,it's the temp from the evening before.
95' 25004X4,AT,Driftwood,Banks Stinger,Warn fender flairs and running boards(Play truck)95 3500,5 speed,Driftwood,Banks&Phscotty,34,000 GCVW apple and tractor hauler(work truck)
[This message has been edited by illflem (edited 12-15-2000). ]
Mine has never seemed to read properly. Seems like it is always 7-10 degrees warmer than it is. I think that it is getting heat from the radiator, because of the mounting location. I have throught about relocating the sensor. Anyone have any ideas?
<font color=blue>"WHITE OBSESSION" 99 Quad Cab, White, SLT, 4x4, 5-sp, 3:54's, Raven cap (cab high), Rhino liner, Stainless Nerf Bars, Stainless Rocker Panels, Tow package, Pro-flap mud flaps with Stainless Cummins "C" add to rear flaps, Valentine One, Uniden PC78LTW CB, Hadley Bully Air Horns, HOT Power Edge, Psychotty Air Induction, Braided SS Fuel Lines, 4" Jardine Exhaust (Love the deep throaty sound), 285/75R16 Cooper A/T's, Navigator 55w backup lights. </font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9265455" TARGET=_blank><font color=red>My 99 Dodge Cummins</A></font>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1086000&a=9815423" TARGET=_blank><font color=green>BD Dyno Days 10/28/00</A></font>
<font color=purple>
Things to come; The clutch has let me know it is going to need attention very soon!
Pyro, 50# Boost and Fuel Pressure gauges (have Ultra lites will install shortly), PE timing module and injectors (have Bully Dog step III injectors ordered), have 2 KC Daylighters (Stainless with 385,000 candlepower each), have 2 KC Fog lamps(Stainless 100w each) and waiting for Smittybilt Stainless Outland Brush Guard to arrive, then will mount guard and lights.
NRA Life Member! (Need to protect our rights and FREEDOM!!)<font size=-2>
[This message has been edited by BIG BOB (edited 12-16-2000). ]
Mine seems slow to react also, much longer than 1 minute. It does seem to be accurate after a few minutes of operation. I have a Taylor 2° increment thermometer and I have checked several times with good comparisons. The delay in reading correct seems to be longer with the onset of colder temperatures. I am watching it, this may be a warranty item!
Shelby
2001. 5 2500 QC LB 4WD, ETH, DEE, 3. 54 gears, Laramie SLT, Camper Special, Trailer Tow, Travel Convenience Group, Power Driver Seat, Alarm System, Remote Keyless Entry, Fog Lamps, Cab Clearance Lamps, HD Transfer Case, Bright White with a Gray Interior. Built 09-15-00, took delivery on 10-06-00, 1749 miles as of 11-25-00. Custom aluminum work body / flat bed. Coming soon: E-Brake and gauges.
Read more in the manual about the thermometer,it says it takes 5 minutes after start up to read correctly,will display the previous shutdown temp for 1 minute. The display shows the average temp over a one minute period. Mine always reads high when I have my winter front installed.
Mine would intermitently read incorrectly, and long after many minutes passed from start-up. Once this year, when I was camping, the temperature was a steady 63 the whole weekend! #ad
Also, if a snowplow is on the truck the reading will be WAY high. #ad
2001. 5 ETH/DEE 2500 4X4 Q. C. SLT Lund Visor Owens Runningboards C R Laurence Power Slider & Others BUT NO POWERTRAIN BOMBING!!!
"The Redneck Toy Box"
And if you have a snow plow on, and Lund winter covers, and are towing 8K, it gets REALLY hot (115 deg). But the engine stayed right at 190. #ad
On my 97, mine always red about 5-8 deg. warm from day one. I replaced the sensor,(located below the left headlight area, behind the bumper) but no change. I played with it quite a while, then moved it straight UP as far as it would go and secured it behind the top edge of the front bumper, and I feel kike it's deadly accururate now. It was picking up warm "prop wash" from the fan. I took it loose from it's factory loction, and moved it straight up as far as I could until it's wire was tight, and screwed it in place. You might try that, I know they are in a different loction on later models, but this fixed mine.
[This message has been edited by Dennis Garrett (edited 12-23-2000). ]
Mine always reads the correct temp, but I do have to drive for a little while first to get it to register the correct temp.
2001 2500HD Quad Cab SLT SB 4x4, HO Cummins, 6-speed, 3. 55 gears, LSD, brightwhite/driftwood, 4w ABS, camper and trailer tow packages, HD transfer case, snow plow prep, group, cab lights, Isspro Boost and Pyrometer gauges mounted on A-pillar, 4" JRE exhaust, BD exhaust brake. 22500 miles as of 11/11/00.
1980 CJ-5, Modified for off-road use, bobbed fenders, 350 TBI, NP435 trans, 4. 56 gears, Dana 300, Dana 44 front, Dana 60 reverse-cut rear axle, ARB air lockers front and rear, 15/35/15 Super Swamper TSL on 10X15 steel rims, Cobra CB, Warn 9000I winch, nerf bars, 1/4" steel rock crawler bumper front and rear, jerri can/spare tire rack, custom roll cage.
