Engine/Transmission (1994 - 1998) ov location?
2nd Gen Non-Engine/Transmission 1997 2500 weight ratings?
It is directly behind the timing housing, between the injection pump and head you will have to lift the line up and back to remove the old valve and install the new one. Grease the sealing washer a bit so it will stick the line so you can install and your off to the races.
