One of the things that we see happening to our VE pumps is the failure of the seal/oval retaining plate on the back side of our pumps. This is a cover plate and O-Ring that closes off the mechanical timing mechanism.
When a lot of advance is used as an initial timing set, and then coupled with the advance of the KSB AND the advance that happens as RPM climbs the plate/O-Ring fail and leak.
Would any of you guys be interested in a potential fix for this problem. I ask because as we push these pumps higher and higher, we see this failure more and more often, and I'm doing some digging to see if we can come up with a fix for this...
What are your thoughts on this idea???? good idea?? bad???
Bob.
Bob.
