I would have guessed your OE tires were Michelin, not BFG. I got about 80k out of my OE Michelins.
When I purchased my 2005 brand new it came with the off-road tire option, which were the BFG Rugged Trail. I find it quite funny that Dodge or anyone would consider the Rugged Trail tires as "Off Road. " They are great running and long lived tires, but they are not designed for "off road" traction. Well, maybe gravel roads!!
New tires installed today at just over 98,600 miles, replacing original tires on 2500 RAM I bought new in 2005Oo.
Original tires were BF Goodrich Rugged Trail TA
New tires are Michelin LTX A/T2 (same size as original); here's hoping for long life on these too.
Guy at Costco was amazed![]()
Spinning on ice must not create any wear!!! But it does create miles!
Just kidding you!!!
Good job.
if you got that many miles out of the originals, why wouldn't you replace them with the same or are they no longer available ?
how much tread was remaining?? thats an incredible amount of miles.
The spare helps to the tune of 20% less miles per tire. 96K = 76,800 miles a tire (each tire has 4/5 of the total miles when rotating the with the spare).I'm at 96k on the OEM Michelins. Loads of tread remaining. I rotate the spare in, so that helps.
-Ryan
We have found the Michelines will last a long long time AFTER they hit about 30% tread left to go. Problem is at this point they are not sufficient to head into a winter with. We compromised and have good luck with Commercial TA's put on in late fall, and replaced Annually at same time with +/- 60,000 miles. This is towing about 7K with LOTS of tongue weight on DRW 4x4's , 100% of the miles.
