Does anyone have any suggestions for a under/overdrive for a 47RE. When I am manually locked up in OD my truck only goes 111 MPH. NOT FAST ENOUGH!!! O ya, and I have 265 x 70 x 17 Michelins
Originally posted by Snow man
you need to cut an orange wire under the hood above the valve cover. This is the speed limiter wire. With that wire cut the truck should do well over 125mph if it has 3. 54's.
Originally posted by Chipstien
According to a speed calculator you should be at 111 MPH at 2900 RPM's and 127 at 3300 RPM's. Are you sure the TC is locking up? My truck with 4. 10's and 315 tires does 120 MPH at 3300 RPM's but I am able to take it a little beyond 3300 so therefore top speed is even higher.
If you put 315 70 r17's on your truck then you would have the capability to go 138 MPH at 3300 RPM's. Is that fast enough for you?![]()
Here you go! http://www.klenger.net/dodge/general-reference/gear-speed-calculator.xls You can thank fellow member klenger for this great calculator.Originally posted by justinp20012500
Where did you find the speed calculator?? My truck dynos @ 417 Hp and 1019 ft/lbs, so i know the converter is locked. I wouldn't be able to get numbers like that it if it wasn't.
Oh yeah, US Gear and Gear Vendors are two companies that make over/under drives.
