Engine/Transmission (1998.5 - 2002) over boost code ????
Engine/Transmission (1998.5 - 2002) Rear Main leak
I am installing the turbomaster waste gate spring just wondering
since i do not have boost fooler yet if i set a over boost code can i clear it on my own i have the obd2 software and cable hope to have a edge comp soon aloha and mahalo for your input
Sorry I can't answer your question, but I was just wondering how you liked your obd2 software. If you got the software from the original http://www.obd-2.com./, apparently it will clear all codes.
overboost
i am not sure where i got it from the link you sent did not work
i guess ill crank down on the adjustment and see if i can clear also just got rid of muffler midas made me a straight pipe i really like the sound Oo. :D
I have a boost fooler and set the code # 0234 as well as the generic code #1693 when at 31 psi. I was really surprised that I overboosted. I have not cleared the code but in the past to clear others I simply disconnected the batteries for about 30 minutes. Codes were gone after that.
Hope that helps lead you to your answer.
R,
Andy
