2nd Gen Non-Engine/Transmission over head computer "CCD" fault...
Engine/Transmission (1998.5 - 2002) My new South Bend con ofe
Engine/Transmission (1998.5 - 2002) high idle??
wandimeek
My over head computer sometimes reads CCD. I have been to two different shops about this problem and no one can explain it. I have a 2000 cummins loaded. The only way to get rid of it is to turn off key a couple times!!! Thanks Walt -- email address removed --
The CCD translates "Chrysler Collision Detection data bus". There is a self diagnostic procedure for the console which is initiated by holding the Step button and the US/Metric down simontaniously and turning the ign. switch on. Hold the buttons until the unit goes into test mode. Book says DRB scan tool is needed. A competent shop should have this information. I have no idea what all this means. bg
I moved this thread over here and changed the title a bit in hopes of more people coming forward with information.
Dan-
Walt,
I can't tell from your post, but if you have an Edge box, that may be causing you a problem. My Edge Comp caused the CCD thing, but was remedied by contacting Edge for a warranty replacement.
Not sure if that helps.
Duane
Did it always do this?
Check your connections, the one in the back of the fuse box might be lose. There is also a connection in the overhead console.
