Do I drop the fuel tank or raise the bed to access the fuel sender for repair? That is the question for my 98. 5 quad cab short bed. Is it quicker/easier to remove the bed which contains a combo toolbox/fuel tank, fifth wheel hitch, and has airbag lifts installed? Or, remove a frame cross brace and lower the fuel tank enough to gain access to the top of tank fuel and electrical connections that are so close to the bed that I can't get my hands in to disconnect them, then lower the tank to repair the fuel tank sending unit? If I could get to the top of tank connections I still can't see how the connections are released. I'd appreciate any advice. I've read where some have loosened the module nut and then the tank dropped leaving the module still connected to the fuel and electrical connections. Good idea or bad. BTW this will be done out of doors on the driveway. TIA, ph
