Hello fellow members,
I borrowed a OBDII scanner tool today and got the notorious over boost code. I've read alot of posts on the overboost and am not too worried about it. Since the engine is stock, I must need a new MAP sensor or I need to work on the wastegate I guess.
Here's what I'm wondering. Since I also have the bad idle when warm problem that I can't figure out, are these two possibly related? If you throw a over boost code, does the engine go into a limp mode that causes a rough idle. What about if the MAP sensor is giving faulty readings, will this cause rough idle?
One more thing. The idle is really rough but if I turn the engine off for a minute or two and restart, it idles great but the intake heater appears to be cycling and won't stop? Is this normal? The truck is still at operating temperature, so why is the heater cycling? I assume it's cycling because the voltmeter drops down for a few seconds and then returns.
Any help is again appreciated and sorry for all the questions but this idle thing is driving me bonkers:{ .
Thanks,
Vance
Thanks,
Vance
