overboost code help
fuel sender
Outside Ambient Temp Sensor
I was on the phone today with a vendor. If u have a blue box 4 wire and leave the green wire disconnected for the boost adapter out and dont use a boostmodule u will get a overboost code correct. Can the code be erased with a snap on scanner. reason being is i drove the truck today with just ez edge and the blue box on 30% and its green wire disconnected and yes we had smoke but wow what a power difference. The reason for asking is I wanna leave the green wire disconnected and try my va again with the blue box but am nervous about the code and also see if this might cure my stumble thanks for your help
99 24v auto 3500 4x4 reg cab 3. 55 axle,va cpc,275 injectors,k&n,rhino lining, tinted glass, tonnoue cover heavy duty trailer tow set up goose neck hitch draw tite brake setup,cb,cd player,catz back up lights,amsoil frnt to back,jre exhaust4 wire blue box, pressure lock,bd exhaust brake,JRE style transgo shift kit, a pro torqe extreme convertor, and a magtec trans cover and trans guage,JRE fuel line kit,upgraded fuel pump,braided fuel lines from lift to injector pump,reflashed ecm,power edge ez,fuel pressure guage,3 guage pillar,boost&pyro
