I have been getting overboost codes with my Edge Comp and earlier with my EZ. See my signature for truck info.
I am finally getting around to upgrading the turbo to a small set of twins and exhaust, and was wondering if anyone has tried a mechanical boost fooler.
I am pondering running a hose from the MAP port into a air pressure regulator, then into the MAP sensor. This should keep the max boost pressure it ever sees at what ever I set it at.
Is this going to cause issues with the Edge Comp as far as fueling and timing? I know the truck ECM will defuel when it sees the overboost codes, but does the Edge rely on accurate boost info for what it does?
