pwerwagn
Ive read through a lot of posts on here and am not sure I found my answer yet.
~3 weekends ago I was prerunning in my 04 for the Cinco De Baja. I got about 5 miles into the track and started to smell something not right. I was a ways ahead of everyone else with us, so I pulled over. My passenger side battery had broke the hold down. The bolt that passes through the battery cable terminal was melted off. This bolt has the alternator fusible link attached to it, as well as the power to the 2 relays next to the passenger batt.
I took the battery out and finished the lap with the alternator disconnected (we had to race the race truck about an hour later... I didnt have time to mess with the dodge). About half way into the loop (40 mile loop) my volt gauge dropped to nothing (I had the race radio on so it was draining the battery).
When I got back I didnt get any time to look at it at all. The next day, I went to start it and it actually started (barely). I tried to hook the alt wire back up and it sparked like crazy, so I figured it shorted something out. So I drove it back home with the 5th wheel with no alt. I charged the battery off the 5th wheel generator for a while so i had trailer brakes. The alt fusible link was still fine.
Anyhow... when I got home i hooked everything back up, started it, and I see ~15V at the passenger batt (which I replaced after the race with a known good one). I disconnected the alt to check, and it full fields at ~50V not hooked to any load. Is that normal-ish? My passenger batt was staying around 15-15. 3 volts every time i checked it (with a fluke, not the dash gauge). So I figured all was well since that seems to be what a lot of people report.
Fast forward to this past friday. I had to use the truck to go rescue my sister/brother in law. He rolled his 05 cummins/5th/jeep on the way to the mtns (everyone is fine), and I had to use my truck to haul his jeep home. I had to sit in traffic for a while because they had the freeway shut down because of the accident. I started to smell another "not right" smell... popped the hood... battery on fire!! I keep fire ext's everywhere so I had it out in 1/2 second.
I do have an optima on the drivers side and a lead-acid on the passenger side. But Ive had a lead acid on the pax side for like 2 years now. The optima is getting bad however... maybe thats part of my problem? Perhaps the alt is trying to charge the optima too hard, and getting the passenger side too hot? Maybe me running the optima dead at the race/trip home did it in?
I would like to say if I replace both battery's I should be ok. But I also dont want to buy 200$ worth of batt's only to burn one up again.
Any suggestions on something to check? Has anyone ever checked alt voltage with no load? The fusible link from the alt didnt seem to "fuse". The very end is melted off now from the fire, but I dont think its melted from excessive amperage.
