!999 120 k use overdrive a lot. I have a BD exhaust brake . Bulb ok and switch OK. Will not shift down into overdrive. Is there a fuse or sensor bad someplace that I need to check?? Thanks
In that case, it's probably an electrical fault somewhere.Sorry shifts fine normal-will not shift into 3rd gear when I push the button on the shifter wand. To keep it in 3rd gear.
Terry,I will check it later today-it seems like I should have some voltage to one side of the switch as it just shunts it to ground to make it work ???
No and no.Is this a FUSED item?? From where ?
There is a transmission control relay in the PDC (Power Distribution Center) which is the black plastic box under the hood on the driver's fender. However, the fact that the transmission shifts normally indicates there's nothing wrong with it. You wouldn't get overdrive in the first place if it were bad.Is there a relay or sensor somewhere that has gone bad OR is there a problem in the transmission. It shifts fine NORMAL etc. No issues.
