Engine/Transmission (1994 - 1998) Overdrive not working
Engine/Transmission (1998.5 - 2002) injectors???
DGamelin
I am looking at a 97 on line and the owner says the OD doesn't work. On our 93 when the TPS goes bad it wont shift into OD. Has anyone seen this on a 97 or have any other ideas?
_____________________________
93 250 2wd xc 354 auto 300k
04. 5 3500 4wd cc dully 373 6speed 149k
Same problem on a 97, TPS could be flaky. With the 47RE you have other added issues, gove solenoid and transducer can cause the same problem. Could also be a bad solenoid or harness on the VB. Worst case, it smoked the OD clutches.
Start by adding a mystery switch and see if the mechanical portion and the solenoid will function. Then do some pressure test to see where everything is at.
